跳转到主内容
Dell Wyse Xn0m Battery Replacement
你所需要的
  1. Dell Wyse Xn0m Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Identify the location of the battery release switches.
  2. Dell Wyse Xn0m Battery Replacement: 步骤 2 中的图像 1,1
    • Slide the left battery release switch to the unlocked position (red showing). This is also indicated by the lock/unlock icons beside the switch.
  3. Dell Wyse Xn0m Battery Replacement: 步骤 3 中的图像 1,2 Dell Wyse Xn0m Battery Replacement: 步骤 3 中的图像 2,2
    • To remove the battery, pull back the right spring-loaded battery release switch while simultaneously sliding the battery away from the laptop.
    • Reassembly tip: when inserting the new battery, make sure the tracks line up right. The battery tracks should sit on top of the laptop body tracks.
结论
另外一个人完成了本指南。
Sam Horne
于10/30/19注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 1,195
