跳转到主内容
加入维修社区 - 创建账户
Dell Vostro V130 Memory Module Replacement
你所需要的
  1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: 步骤 2 中的图像 1,1
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: 步骤 3 中的图像 1,1
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: 步骤 4 中的图像 1,1
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 Memory Module Replacement, Lift the Battery: 步骤 5 中的图像 1,1
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 Memory Module Replacement, LED Cover: 步骤 6 中的图像 1,1
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  7. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: 步骤 7 中的图像 1,1
    • Pull the LED cover toward the keyboard and remove it from the computer.
  8. Dell Vostro V130 Memory Module Replacement, Memory Module: 步骤 8 中的图像 1,1
    • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  9. Dell Vostro V130 Memory Module Replacement: 步骤 9 中的图像 1,1
    • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
终点
Johnathan Hammond
于02/28/18注册
45,582 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
44 名成员
创作了1,996篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 440
