跳转到主内容
Dell Vostro A90 Solid-State Drive Removal
你所需要的
  1. Dell Vostro A90 Solid-State Drive Removal, Removing the Battery: 步骤 1 中的图像 1,1
    • Turn the computer over.
    • Slide the battery-bay release latch and the battery-lock latch towards the outer edges.
    • Slide the battery out of the battery bay.
    • Turn the computer top-side up, open the display, and press the power button to ground the system board.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro A90 Solid-State Drive Removal, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the two screws on the module cover.
  3. Dell Vostro A90 Solid-State Drive Removal, Lifting the Cover: 步骤 3 中的图像 1,1
    • Lift the cover off the computer at an angle as shown in the figure.
  4. Dell Vostro A90 Solid-State Drive Removal, Remove Solid-State Drive: 步骤 4 中的图像 1,1
    • Remove the two screws that secure the solid-state drive.
    • Lift the solid-state drive out of its system board connector.
终点
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
44,953 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
一条评论
Remember the add the Warning steps that are found in the Service Manuals at the beginning of the guides.
Terrence15 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 12
总计 183
