跳转到主内容
Dell Vostro A860 RAM Memory Sticks Replacement
你所需要的
  1. Dell Vostro A860 RAM Memory Sticks Replacement, RAM: 步骤 1 中的图像 1,2 Dell Vostro A860 RAM Memory Sticks Replacement, RAM: 步骤 1 中的图像 2,2
    • With the computer facing down locate the RAM compartment cover.
    • Unscrew the two screws holding the cover to the laptop chassis.
    • The screws do not remove completely, they are clipped into the compartment cover.
    • Lift up on the Memory cover and remove.
  2. Dell Vostro A860 RAM Memory Sticks Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool push outward on both sides of the RAM stick.
    • doing this will release the silver tension clips holding the memory sticks in place. Once released the stick will easily lift up and out of the unit.
结论
Joshua Dennis
于03/25/16注册
528 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-5, Miles Spring 2016 UMass Dartmouth, Team 1-5, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 433
