简介
Replacing the power button is a simple task following this guide, be careful to not disturb any of the surrounding wires when removing the switch.
你所需要的
Remove the battery and set it aside, there is a small clip that slides to free the battery.
Unscrew the two 4.7mm screws below the battery.
With the keyboard removed use the plastic opening tool to lift the black clip holding the connector ribbon for the power switch.
Gently pull out the connector ribbon from the inlet using the attached plastic pull
即将完成!
结论
