简介
The screen bezel and LCD display may come factory assembled with a glue or adhesive holding it together. When removing the display must be held outward to remove the screen.
你所需要的
Remove the battery and set it aside, there is a small clip that slides to free the battery.
Unscrew the two 4.7mm screws below the battery.
Using a plastic opening tool remove the rubber bumpers covering the display bezel screws.
Remove the six 5.5mm screws holding the bezel on.
Remove the following screws:
Two 5.5mm screws from the left display mount.
Two 5.5mm screws from the right display mount.
Gently pull the display mount frame outward to release the inserts holding the display screen in place. This will allow the screen to lean forward, revealing the connectors.
Using a flat headed tool or nail, remove the wires from the right connector behind the display.
Using a flat headed tool or nail, disconnect the wires from the left connection behind the display.
Pulling upward gently on the tab, remove the magnetic connection in the top left of the tray area under the keyboard.
