跳转到主内容
Dell Vostro 5560 Battery Replacement
你所需要的
  1. Dell Vostro 5560 Battery Replacement, Removing The Optical-Disk Drive: 步骤 1 中的图像 1,1
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Battery Replacement, Replacing the Base Cover: 步骤 2 中的图像 1,2 Dell Vostro 5560 Battery Replacement, Replacing the Base Cover: 步骤 2 中的图像 2,2
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Battery Replacement, Removing the Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
终点
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
45,237 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 333
