跳转到主内容
Dell Vostro 5510 Battery Replacement
你所需要的
  1. Dell Vostro 5510 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Battery Replacement: 步骤 3 中的图像 1,3 Dell Vostro 5510 Battery Replacement: 步骤 3 中的图像 2,3 Dell Vostro 5510 Battery Replacement: 步骤 3 中的图像 3,3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Battery Replacement: 步骤 4 中的图像 1,3 Dell Vostro 5510 Battery Replacement: 步骤 4 中的图像 2,3 Dell Vostro 5510 Battery Replacement: 步骤 4 中的图像 3,3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Battery Replacement: 步骤 6 中的图像 1,3 Dell Vostro 5510 Battery Replacement: 步骤 6 中的图像 2,3 Dell Vostro 5510 Battery Replacement: 步骤 6 中的图像 3,3
    • Lift the battery to remove it
结论
另外一个人完成了本指南。
Abril Alejos
于02/09/23注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 44
总计 480
