跳转到主内容
Dell Vostro 5480 Hard Drive Replacement
你所需要的
  1. Dell Vostro 5480 Hard Drive Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro 5480 Hard Drive Replacement, Pry the Cover: 步骤 2 中的图像 1,1
    • Pry the base cover along the edges to loosen it.
  3. Dell Vostro 5480 Hard Drive Replacement, Removing the Base Cover: 步骤 3 中的图像 1,1
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 5480 Hard Drive Replacement, Disconnecting the Battery Cable: 步骤 4 中的图像 1,1
    • Disconnect the battery cable from its connector on the system board.
  5. Dell Vostro 5480 Hard Drive Replacement, Release the Tabs: 步骤 5 中的图像 1,1
    • Release the tabs that secure the battery in the battery bay.
  6. Dell Vostro 5480 Hard Drive Replacement, Removing the Battery: 步骤 6 中的图像 1,1
    • Lift and remove the battery from the computer.
  7. Dell Vostro 5480 Hard Drive Replacement, Removing the Hard Drive: 步骤 7 中的图像 1,1
    • Lift the hard drive assembly in an upward direction to release it from its compartment on the computer. Remove the hard drive from the computer.
  8. Dell Vostro 5480 Hard Drive Replacement, Remove the Screws: 步骤 8 中的图像 1,1
    • Remove the screws that secure the hard drive to the hard drive assembly.
    • Lift and remove the hard drive from the hard drive assembly.
终点
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
45,034 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,312
