跳转到主内容
Dell Vostro 5459 Memory Module Replacement
你所需要的
  1. Dell Vostro 5459 Memory Module Replacement, Removing the Base Cover: 步骤 1 中的图像 1,1
    • Remove the screws that secure the back cover to the computer.
    • Pry the edges of the back cover from all sides, to release the back cover.
    • Lift the back cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5459 Memory Module Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  3. Dell Vostro 5459 Memory Module Replacement, Removing the Memory Module: 步骤 3 中的图像 1,1
    • Lift the plastic enclosure covering the top of the memory module compartment.
    • Pull the retention clips from the memory module until it pops up.
    • Remove the memory module from the connector on the system board.
结论
Johnathan Hammond
于02/28/18注册
45,555 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,994篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 328
