跳转到主内容
Dell Vostro 5459 Hard Drive Replacement
你所需要的
  1. Dell Vostro 5459 Hard Drive Replacement, Removing the Base Cover: 步骤 1 中的图像 1,1
    • Remove the screws that secure the back cover to the computer.
    • Pry the edges of the back cover from all sides, to release the back cover.
    • Lift the back cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5459 Hard Drive Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  3. Dell Vostro 5459 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Disconnect the hard drive cable from the connector on the system board [1] .
    • Remove the screws that secure the hard drive to the computer [2].
    • Lift the hard drive from the computer [3].
结论
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
45,237 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
一条评论
Dell Vostro 14 5459 definitely is simple and easy to open. In absence of prying tool you can use even disposable plastic knife. Spent 15 minutes to disassemble, change HDD drive to SSD drive and assemble it back. Memory upgrade is easy as well - carefully peel off plastic sheet above RAM module and replace the RAM. Seems particular cooler design is not very prone to collect dust inside too so easier cleaning as well. If middle screw on assembly doesn’t stick in thread, slightly press keyboard in area where keys G,H,J are and try to screw the screw in again. For maintenance and upgrade for this laptop I give 4/5.
Jānis Baumanis - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,125
