跳转到主内容
Dell Vostro 3550 Display Assembly Replacement
你所需要的
  1. Dell Vostro 3550 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,2 Dell Vostro 3550 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,2
    • Grip the back trim of the laptop and pull upwards to remove it.
  2. Dell Vostro 3550 Display Assembly Replacement: 步骤 2 中的图像 1,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 2 中的图像 2,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 2 中的图像 3,3
    • Slide the plastic opening tool around the perimeter of the display bezel.
    • Carefully remove the bezel from the display.
  3. Dell Vostro 3550 Display Assembly Replacement: 步骤 3 中的图像 1,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 3 中的图像 2,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 3 中的图像 3,3
    • Remove the six 7 mm Phillips #0 screws attaching the display to the upper casing of the laptop.
    • When all six screws are removed, gently lower the display to reveal the camera cable.
  4. Dell Vostro 3550 Display Assembly Replacement: 步骤 4 中的图像 1,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 4 中的图像 2,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Disconnect the camera ribbon cable by gently pulling it away from its connector.
  5. Dell Vostro 3550 Display Assembly Replacement: 步骤 5 中的图像 1,2 Dell Vostro 3550 Display Assembly Replacement: 步骤 5 中的图像 2,2
    • Remove the four 5 mm Phillips #0 screws (two on either side) securing the display to the metal frame.
  6. Dell Vostro 3550 Display Assembly Replacement: 步骤 6 中的图像 1,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 6 中的图像 2,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Gently lower the display into a resting position.
  7. Dell Vostro 3550 Display Assembly Replacement: 步骤 7 中的图像 1,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 7 中的图像 2,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 7 中的图像 3,3
    • Loosen the clear tape fastening the ribbon cable to the display.
    • Carefully pull the ribbon cable away from the connector.
  8. Dell Vostro 3550 Display Assembly Replacement: 步骤 8 中的图像 1,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 8 中的图像 2,3 Dell Vostro 3550 Display Assembly Replacement: 步骤 8 中的图像 3,3
    • Peel the ribbon cable away from the display.
    • Remove the display from the laptop.
结论
Dylan J. Souza
于03/22/19注册
781 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 22
总计 787
