跳转到主内容
Dell Vostro 3550 Disk Drive Tray Latch Replacement
你所需要的
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: 步骤 1 中的图像 1,3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: 步骤 1 中的图像 2,3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: 步骤 1 中的图像 3,3
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 2 中的图像 1,3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 2 中的图像 2,3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 3 中的图像 1,3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 3 中的图像 2,3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 3 中的图像 3,3
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 4 中的图像 1,3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 4 中的图像 2,3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: 步骤 4 中的图像 3,3
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
结论
Dylan J. Souza
于03/22/19注册
781 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 252
