跳转到主内容
Dell Vostro 3450 Palm Rest Replacement
你所需要的
  1. Dell Vostro 3450 Palm Rest Replacement, Unlocking the Battery: 步骤 1 中的图像 1,1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Palm Rest Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Palm Rest Replacement, Loosen the Screw: 步骤 3 中的图像 1,1
    • Loosen the screw that secures the memory door.
  4. Dell Vostro 3450 Palm Rest Replacement, Removing the Memory Door: 步骤 4 中的图像 1,1
    • Pry up the memory door near the screw hole, lift and remove it.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Palm Rest Replacement, Remove the Screw: 步骤 5 中的图像 1,1
    • Remove the screw that secures the optical drive to the computer.
  6. Dell Vostro 3450 Palm Rest Replacement, Prying the Drive: 步骤 6 中的图像 1,1
    • Gently pry the optical drive out of the computer.
  7. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: 步骤 7 中的图像 1,1
    • Remove the screws that secure the optical drive bracket.
  8. Dell Vostro 3450 Palm Rest Replacement, Removing the Optical Drive: 步骤 8 中的图像 1,1
    • Remove the optical drive bracket from the optical drive module.
  9. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: 步骤 9 中的图像 1,1
    • Remove the screws in the battery compartment.
  10. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: 步骤 10 中的图像 1,1
    • Remove the screws in the optical drive compartment.
  11. Dell Vostro 3450 Palm Rest Replacement, Remove the Rubber: 步骤 11 中的图像 1,1
    • Remove the rubber from the bottom base on the right side.
  12. Dell Vostro 3450 Palm Rest Replacement, Remove the Rubber: 步骤 12 中的图像 1,1
    • Remove the rubber from the bottom base on the left side.
  13. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: 步骤 13 中的图像 1,1
    • Remove all the screws from the bottom base.
  14. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: 步骤 14 中的图像 1,1
    • Flip the computer around and remove the screws that secures the palm rest.
  15. Dell Vostro 3450 Palm Rest Replacement, Release the Latches: 步骤 15 中的图像 1,1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  16. Dell Vostro 3450 Palm Rest Replacement, Release the Latch: 步骤 16 中的图像 1,1
    • Release the latch on the system board connector and then disconnect the power button cable.
  17. Dell Vostro 3450 Palm Rest Replacement, Disconnecting the Key Cable: 步骤 17 中的图像 1,1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  18. Dell Vostro 3450 Palm Rest Replacement, Prying the Palm Rest: 步骤 18 中的图像 1,1
    • Pry up the right side of the palm rest.
  19. Dell Vostro 3450 Palm Rest Replacement, Prying the Palm Rest: 步骤 19 中的图像 1,1
    • Pry up the left side of the palm rest.
  20. Dell Vostro 3450 Palm Rest Replacement, Prying the Sides: 步骤 20 中的图像 1,1
    • Pry up the sides of the palm rest and remove it from the computer.
终点
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
44,953 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 134
