跳转到主内容
Dell Vostro 3450 Optical Drive Replacement
你所需要的
  1. Dell Vostro 3450 Optical Drive Replacement, Unlocking the Battery: 步骤 1 中的图像 1,1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Optical Drive Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Optical Drive Replacement, Loosen the Screw: 步骤 3 中的图像 1,1
    • Loosen the screw that secures the memory door.
  4. Dell Vostro 3450 Optical Drive Replacement, Removing the Memory Door: 步骤 4 中的图像 1,1
    • Pry up the memory door near the screw hole, lift and remove it.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Optical Drive Replacement, Remove the Screw: 步骤 5 中的图像 1,1
    • Remove the screw that secures the optical drive to the computer.
  6. Dell Vostro 3450 Optical Drive Replacement, Prying the Drive: 步骤 6 中的图像 1,1
    • Gently pry the optical drive out of the computer.
  7. Dell Vostro 3450 Optical Drive Replacement, Remove the Screws: 步骤 7 中的图像 1,1
    • Remove the screws that secure the optical drive bracket.
  8. Dell Vostro 3450 Optical Drive Replacement, Removing the Optical Drive: 步骤 8 中的图像 1,1
    • Remove the optical drive bracket from the optical drive module.
终点
2等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
44,953 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 10
总计 171
