简介
In this guide, we will be showing you how to remove and replace the Palm-Rest.
你所需要的
Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
Lift the clip to release the keyboard cable and disconnect it from the computer.
Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
Disconnect the power LED cable and the LED board cable from the system board.
Pry along the edges of the palmrest to release the palmrest.
另外一个人完成了本指南。
