简介
In this guide, we will show you how to remove and replace the Memory Module.
你所需要的
Slide both battery latches to the open position.
Slide the battery out of the battery bay.
Loosen the eight screws that secure the memory cover.
Remove the memory cover and set it aside.
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Remove the memory module from the connector.
终点
另外一个人完成了本指南。
