跳转到主内容
Dell Vostro 1710 Heatsink Replacement
你所需要的
  1. Dell Vostro 1710 Heatsink Replacement, Battery: 步骤 1 中的图像 1,2 Dell Vostro 1710 Heatsink Replacement, Battery: 步骤 1 中的图像 2,2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Heatsink Replacement: 步骤 2 中的图像 1,1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Heatsink Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Heatsink Replacement, Back Panel: 步骤 4 中的图像 1,2 Dell Vostro 1710 Heatsink Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Heatsink Replacement: 步骤 5 中的图像 1,1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Heatsink Replacement, Fan: 步骤 6 中的图像 1,2 Dell Vostro 1710 Heatsink Replacement, Fan: 步骤 6 中的图像 2,2
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Dell Vostro 1710 Heatsink Replacement: 步骤 7 中的图像 1,2 Dell Vostro 1710 Heatsink Replacement: 步骤 7 中的图像 2,2
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Dell Vostro 1710 Heatsink Replacement: 步骤 8 中的图像 1,2 Dell Vostro 1710 Heatsink Replacement: 步骤 8 中的图像 2,2
    • Gently lift and pull to the left until the fan is free from the heatsink.
  9. Dell Vostro 1710 Heatsink Replacement, Heatsink: 步骤 9 中的图像 1,2 Dell Vostro 1710 Heatsink Replacement, Heatsink: 步骤 9 中的图像 2,2
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  10. Dell Vostro 1710 Heatsink Replacement: 步骤 10 中的图像 1,2 Dell Vostro 1710 Heatsink Replacement: 步骤 10 中的图像 2,2
    • Lift up on the heatsink to remove it from the laptop.
结论
另外一个人完成了本指南。
Tangxiao Sun
于03/19/18注册
496 声望
创作了4篇指南
团队
UMass Dartmouth, Team S3-G7, Peak Spring 2018 UMass Dartmouth, Team S3-G7, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G7
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 272
