跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Dell Vostro 15 3565 Hard Drive Bracket Replacement
你所需要的
  1. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Optical-Disk Drive: 步骤 2 中的图像 1,1
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3565 Hard Drive Bracket Replacement, KeyBoard: 步骤 3 中的图像 1,1
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Dell Vostro 15 3565 Hard Drive Bracket Replacement: 步骤 4 中的图像 1,1
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Dell Vostro 15 3565 Hard Drive Bracket Replacement: 步骤 5 中的图像 1,1
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Base Cover: 步骤 6 中的图像 1,1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Dell Vostro 15 3565 Hard Drive Bracket Replacement: 步骤 7 中的图像 1,1
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  8. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Hard Drive: 步骤 8 中的图像 1,1
    • Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Remove the screws that secure the hard drive assembly to the computer [3].
    • Lift the hard drive assembly away from the computer [4].
  9. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Hard Drive Bracket: 步骤 9 中的图像 1,1
    • Pull the hard drive cable connector to remove it from the hard drive [1].
    • Remove the screws that secure the hard drive bracket to the hard drive [2].
    • Lift the hard drive from the hard drive bracket [3].
结论
Johnathan Hammond
于02/28/18注册
44,820 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 63
