跳转到主内容
配件
没有特定配件。
  1. Slide the release latch to unlock the battery [1].
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Remove the screw that secures the optical drive to the computer [1].
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Release the keyboard by prying on the keyboard release tabs by using a scribe.
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Disconnect the keyboard cable from the system board [1].
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Remove the screws that secure the base cover to the computer [1].
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
结论
Johnathan Hammond
于2018年02月28日注册
38,265 信誉积分
创作了408篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
38 名成员
创作了1,973篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 46
