配件
无需配件。
  1. Slide the release latch to release the battery [1].
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Remove the M2L3 screw that secures the optical drive to the computer [1].
    • Remove the M2L3 screw that secures the optical drive to the computer [1].
      • Using a plastic scribe, push the tab in the direction of the arrow indicated on the chassis. [2].
        • Slide the optical drive out of the computer [3].
    • Using a plastic scribe, release the five tabs from the slots located above the keyboard [1].
      • Flip the keyboard on the palm rest to access the keyboard connector cable under the keyboard [2].
    • Disconnect the keyboard cable from the system board.
      • Remove the keyboard from the computer.
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
      • Remove the M2L5 screws that secure the base cover [2].
    • Flip the computer and remove the screws (8 screws - M2.5L8; 3 screws - M2L2; 2 screws- M2L2) that secure the base cover to the computer.
    • Use a scribe to pry the edges of the base cover [1].
      • Lift the base cover and remove it from the computer [2].
    • Disconnect the hard drive cable from the connector on the system board [1].
      • Remove the M2L3 screws that secure the hard drive assembly to the computer [2].
        • Lift the hard drive assembly away from the computer [3].
结论
另外一个人完成了本指南。
Johnathan Hammond
于2018年02月28日注册
35,827 信誉积分
创作了408篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
15 名成员
创作了925篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 2
总计 43
