跳转到主内容
Dell Vostro 1400 Screen Replacement
你所需要的
  1. Dell Vostro 1400 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Screen Replacement: 步骤 2 中的图像 1,1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Screen Replacement: 步骤 3 中的图像 1,2 Dell Vostro 1400 Screen Replacement: 步骤 3 中的图像 2,2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Screen Replacement, Screen: 步骤 4 中的图像 1,1
    • Please make sure your device is completely turned off and everything is unplugged from the device
    • Open the laptop.
  5. Dell Vostro 1400 Screen Replacement: 步骤 5 中的图像 1,2 Dell Vostro 1400 Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the 6 screw hole covers surrounding the screen.
    • Remove the 6 screws that were underneath the screw covers.
  6. Dell Vostro 1400 Screen Replacement: 步骤 6 中的图像 1,2 Dell Vostro 1400 Screen Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
    • Remove the two (2.5mm x 5mm) screws at the top, by the camera.
  7. Dell Vostro 1400 Screen Replacement: 步骤 7 中的图像 1,2 Dell Vostro 1400 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the two 5mm screws from the camera above the screen.
    • Remove the two 5mm screws from the bottom of the screen.
  8. Dell Vostro 1400 Screen Replacement: 步骤 8 中的图像 1,2 Dell Vostro 1400 Screen Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the screen from the back cover.
  9. Dell Vostro 1400 Screen Replacement: 步骤 9 中的图像 1,2 Dell Vostro 1400 Screen Replacement: 步骤 9 中的图像 2,2
    • Lift up the black tag holding the camera and cable together.
    • Unplug the camera from the cable.
  10. Dell Vostro 1400 Screen Replacement: 步骤 10 中的图像 1,3 Dell Vostro 1400 Screen Replacement: 步骤 10 中的图像 2,3 Dell Vostro 1400 Screen Replacement: 步骤 10 中的图像 3,3
    • Unplug the two cables connected to the screen.
  11. Dell Vostro 1400 Screen Replacement: 步骤 11 中的图像 1,2 Dell Vostro 1400 Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the six 3mm screws on each side of the screen.
    • Remove the railing on each side of the screen.
    • The railing will be marked "L" for left side or "R" for the right. This should assist in reassembly.
结论
2等其他人完成本指南。
David Hogg
于03/20/17注册
727 声望
创作了5篇指南
团队
Texas Tech, Team S8-G2, Bennett Spring 2017 Texas Tech, Team S8-G2, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 650
