你所需要的
Slide the release latch to unlock the battery [1].
Remove the battery from the computer [2].
Remove the screw that secures the optical drive to the computer [1].
Using a plastic scribe, push the tab to release the optical drive [2].
Slide the optical drive out of the computer [3].
Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
Disconnect the optical drive connector and lift it to remove it from the system board [1].
Remove the screws inside the palmrest [2].
Disconnect the hard drive cable from the connector on the system board [1].
Remove the screws that secure the hard drive assembly to the computer [2].
Lift the hard drive assembly away from the computer [3].
另外一个人完成了本指南。
