跳转到主内容
Dell Vostro 1310 Memory Module Replacement
你所需要的
  1. Dell Vostro 1310 Memory Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery lock to the open position. {2}
    • Slide the battery latch release to the open position. (You may need to hold the latch release in the open position while removing the battery.){3}
    • Slide the battery out of the battery bay. {1}
  2. Dell Vostro 1310 Memory Module Replacement, Memory Module: 步骤 2 中的图像 1,1
    • Remove the M2.5 x 5-mm screw that secures the memory cover, and remove the cover and set it aside.
  3. Dell Vostro 1310 Memory Module Replacement: 步骤 3 中的图像 1,1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
结论
Johnathan Hammond
于02/28/18注册
44,830 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 168
