跳转到主内容
Dell Venue 8 Display Replacement
你所需要的
  1. Dell Venue 8 Display Replacement, Rear Case/Midframe: 步骤 1 中的图像 1,1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Display Replacement: 步骤 2 中的图像 1,3 Dell Venue 8 Display Replacement: 步骤 2 中的图像 2,3 Dell Venue 8 Display Replacement: 步骤 2 中的图像 3,3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Display Replacement, Battery: 步骤 3 中的图像 1,1
    • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
  4. Dell Venue 8 Display Replacement: 步骤 4 中的图像 1,1
    • Gently pry the battery away from the device with the plastic opening tool to remove it.
    • The battery is held on to the tablet by a light adhesive
  5. Dell Venue 8 Display Replacement, Speaker: 步骤 5 中的图像 1,1
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
  6. Dell Venue 8 Display Replacement: 步骤 6 中的图像 1,1
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
  7. Dell Venue 8 Display Replacement, Display: 步骤 7 中的图像 1,2 Dell Venue 8 Display Replacement, Display: 步骤 7 中的图像 2,2
    • Disconnect the display clip found next to the speaker.
    • Disconnect the Display connection located at the top of the tablet.
  8. Dell Venue 8 Display Replacement: 步骤 8 中的图像 1,1
    • Unclip the logic board from the Display.
结论
7等其他人完成本指南。
Mitul
于02/19/15注册
673 声望
撰写一个指南
团队
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G2
3 名成员
创作了12篇指南
2条评论
LOL. Who rated this as a difficult repair? Seriously? T5 screws too much for you? The only issue with the repair for this device is the adhesive between the digi and frame is a REAL pain to remove, and the plastic frame is likely to melt if you use too much/high heat. Otherwise, it's very simple. Just be careful when installing the new digi, as the motherboard needs to be slightly lifted to feed the connector.
Rene - 回复
Thanks for the instructions!
Is there a part 2 for this guide? The instructions is incomplete and doesn't not include steps to actually remove the digitizer.
Franklin Ramos - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 26
总计 7,129
