跳转到主内容
Dell Venue 8 Back Camera Replacement
你所需要的
  1. Dell Venue 8 Back Camera Replacement, Rear Case/Midframe: 步骤 1 中的图像 1,1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Back Camera Replacement: 步骤 2 中的图像 1,3 Dell Venue 8 Back Camera Replacement: 步骤 2 中的图像 2,3 Dell Venue 8 Back Camera Replacement: 步骤 2 中的图像 3,3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Back Camera Replacement, Back Camera: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to disconnect the camera from the logic board, by prying it up.
结论
另外一个人完成了本指南。
Andrea
于02/19/15注册
1,071 声望
创作了5篇指南
团队
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G2
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 1,053
