跳转到主内容
Dell Venue 8 7840 Screen Replacement
你所需要的
  1. Dell Venue 8 7840 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Screen Replacement: 步骤 2 中的图像 1,1
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Screen Replacement: 步骤 3 中的图像 1,1
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Screen Replacement: 步骤 4 中的图像 1,1
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Screen Replacement: 步骤 5 中的图像 1,1
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Screen Replacement: 步骤 6 中的图像 1,1
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Screen Replacement: 步骤 7 中的图像 1,1
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Screen Replacement: 步骤 8 中的图像 1,1
    • Disconnect the connector from the tablet.
结论
团队
USF Tampa, Team 6-5, Remmell Fall 2016 USF Tampa, Team 6-5, Remmell Fall 2016 的会员
USFT-REMMELL-F16S6G5
3 名成员
创作了6篇指南
3条评论
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
dengzc - 回复
Where can I find a replacement screen for this device?
Karim Mohamed - 回复
Is the OLED connected with EDP 30=pin FPC?
Ron King - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 1,415
