跳转到主内容
Dell Venue 7 Speaker Replacement
你所需要的
  1. Dell Venue 7 Speaker Replacement, Rear Case: 步骤 1 中的图像 1,2 Dell Venue 7 Speaker Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Speaker Replacement, Battery: 步骤 2 中的图像 1,1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Dell Venue 7 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  5. Dell Venue 7 Speaker Replacement: 步骤 5 中的图像 1,2 Dell Venue 7 Speaker Replacement: 步骤 5 中的图像 2,2
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  6. Dell Venue 7 Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the plastic covering on the speaker.
  7. Dell Venue 7 Speaker Replacement: 步骤 7 中的图像 1,2 Dell Venue 7 Speaker Replacement: 步骤 7 中的图像 2,2
    • Gently pull on the wire and remove the speaker.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 785
