跳转到主内容
Dell Venue 7 Rear Facing Camera Replacement
你所需要的
  1. Dell Venue 7 Rear Facing Camera Replacement, Rear Case: 步骤 1 中的图像 1,2 Dell Venue 7 Rear Facing Camera Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Rear Facing Camera Replacement, Battery: 步骤 2 中的图像 1,1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Rear Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Rear Facing Camera Replacement, Rear Facing Camera: 步骤 4 中的图像 1,1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Rear Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the camera from the device.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 455
