跳转到主内容
Dell Venue 7 Motherboard Replacement
你所需要的
  1. Dell Venue 7 Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,2 Dell Venue 7 Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Motherboard Replacement, Battery: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: 步骤 4 中的图像 1,1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the camera from the device.
  6. Dell Venue 7 Motherboard Replacement, Speaker: 步骤 6 中的图像 1,2 Dell Venue 7 Motherboard Replacement, Speaker: 步骤 6 中的图像 2,2
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  7. Dell Venue 7 Motherboard Replacement: 步骤 7 中的图像 1,2 Dell Venue 7 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  8. Dell Venue 7 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the plastic covering on the speaker.
  9. Dell Venue 7 Motherboard Replacement: 步骤 9 中的图像 1,2 Dell Venue 7 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Gently pull on the wire and remove the speaker.
  10. Dell Venue 7 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,3 Dell Venue 7 Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,3 Dell Venue 7 Motherboard Replacement, Motherboard: 步骤 10 中的图像 3,3
    • Disconnect the two remaining connections on the motherboard.
    • To remove the first connector, lift up the clasp and remove the ribbon cable.
    • To remove the second one, use a spudger to gently pry the connector from the motherboard.
  11. Dell Venue 7 Motherboard Replacement: 步骤 11 中的图像 1,2 Dell Venue 7 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
  12. Dell Venue 7 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Lift and remove the motherboard from the device.
结论
8等其他人完成本指南。
团队
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S11G4
4 名成员
创作了10篇指南
2条评论
unable to open the lock, can the mother board be changed
Amitabh Mishra - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 4,445
