跳转到主内容
简介
If your Dell VRP100 headset has a cracked, scratched or broken lens you are definitely going to want to replace it. This guide has all the steps for you need replace those beat up lenses with new ones. You will need a metal spudger for parts of this guide.
  1. Dell VRP100 Lens Replacement, Cover Panel: 步骤 1 中的图像 1,3 Dell VRP100 Lens Replacement, Cover Panel: 步骤 1 中的图像 2,3 Dell VRP100 Lens Replacement, Cover Panel: 步骤 1 中的图像 3,3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Lens Replacement: 步骤 2 中的图像 1,1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Lens Replacement: 步骤 3 中的图像 1,3 Dell VRP100 Lens Replacement: 步骤 3 中的图像 2,3 Dell VRP100 Lens Replacement: 步骤 3 中的图像 3,3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Lens Replacement: 步骤 4 中的图像 1,3 Dell VRP100 Lens Replacement: 步骤 4 中的图像 2,3 Dell VRP100 Lens Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Lens Replacement, Lens: 步骤 5 中的图像 1,2 Dell VRP100 Lens Replacement, Lens: 步骤 5 中的图像 2,2
    • Deattach the black cover from the lens with a metal spudger.
    • This will “click” back into place during replacement.
  6. Dell VRP100 Lens Replacement: 步骤 6 中的图像 1,3 Dell VRP100 Lens Replacement: 步骤 6 中的图像 2,3 Dell VRP100 Lens Replacement: 步骤 6 中的图像 3,3
    • Gently insert the metal spudger between the lens and the lens casing.
    • Rotate the spudger around the exterior of the lens and lens housing, separating them.
    • The lens is held in place with an adhesive that will have to be applied during reassembly.
  7. Dell VRP100 Lens Replacement: 步骤 7 中的图像 1,1
    • Holding the lens around the outside, gently lift it out of its housing.
结论
另外一个人完成了本指南。
Chris Grabow
于2018年10月08日注册
285 声望分
创作了2篇指南
团队
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 的会员
CPSU-WHITE-F18S17G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 590
