跳转到主内容
加入维修社区 - 创建账户
Dell VRP100 Camera Replacement
你所需要的
  1. Dell VRP100 Camera Replacement, Cover Panel: 步骤 1 中的图像 1,3 Dell VRP100 Camera Replacement, Cover Panel: 步骤 1 中的图像 2,3 Dell VRP100 Camera Replacement, Cover Panel: 步骤 1 中的图像 3,3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Camera Replacement: 步骤 3 中的图像 1,3 Dell VRP100 Camera Replacement: 步骤 3 中的图像 2,3 Dell VRP100 Camera Replacement: 步骤 3 中的图像 3,3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Camera Replacement: 步骤 4 中的图像 1,3 Dell VRP100 Camera Replacement: 步骤 4 中的图像 2,3 Dell VRP100 Camera Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Camera Replacement, Camera: 步骤 5 中的图像 1,3 Dell VRP100 Camera Replacement, Camera: 步骤 5 中的图像 2,3 Dell VRP100 Camera Replacement, Camera: 步骤 5 中的图像 3,3
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  6. Dell VRP100 Camera Replacement: 步骤 6 中的图像 1,2 Dell VRP100 Camera Replacement: 步骤 6 中的图像 2,2
    • Remove the two 2.5mm PH000 screws from the motherboard by rotating counter-clockwise.
    • Remove the four 3.9mm PH000 screws from the white casing by rotating counter-clockwise.
  7. Dell VRP100 Camera Replacement: 步骤 7 中的图像 1,2 Dell VRP100 Camera Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the flat-topped connector by lifting it straight up from the motherboard.
    • Carefully remove the camera from the casing with the blunt nose tweezers by holding onto the copper tape.
    • To reinstall, line up the connectors and firmly push until you hear a pop.
结论
另外一个人完成了本指南。
Lauren Monzon
于10/08/18注册
235 声望
创作了2篇指南
团队
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 的会员
CPSU-WHITE-F18S17G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 542
