跳转到主内容
Dell VRP100 Auxiliary Cord Replacement
你所需要的
  1. Dell VRP100 Auxiliary Cord Replacement, Cover Panel: 步骤 1 中的图像 1,3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: 步骤 1 中的图像 2,3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: 步骤 1 中的图像 3,3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Auxiliary Cord Replacement: 步骤 2 中的图像 1,1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Auxiliary Cord Replacement: 步骤 3 中的图像 1,3 Dell VRP100 Auxiliary Cord Replacement: 步骤 3 中的图像 2,3 Dell VRP100 Auxiliary Cord Replacement: 步骤 3 中的图像 3,3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Auxiliary Cord Replacement: 步骤 4 中的图像 1,3 Dell VRP100 Auxiliary Cord Replacement: 步骤 4 中的图像 2,3 Dell VRP100 Auxiliary Cord Replacement: 步骤 4 中的图像 3,3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: 步骤 5 中的图像 1,3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: 步骤 5 中的图像 2,3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: 步骤 5 中的图像 3,3
    • Separate the external connector of the auxiliary cord.
    • A spudger may be needed to separate the connector.
  6. Dell VRP100 Auxiliary Cord Replacement: 步骤 6 中的图像 1,2 Dell VRP100 Auxiliary Cord Replacement: 步骤 6 中的图像 2,2
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  7. Dell VRP100 Auxiliary Cord Replacement: 步骤 7 中的图像 1,3 Dell VRP100 Auxiliary Cord Replacement: 步骤 7 中的图像 2,3 Dell VRP100 Auxiliary Cord Replacement: 步骤 7 中的图像 3,3
    • In the top right corner of the motherboard panel, peel back the yellow tape covering the bundled auxiliary cable connector using tweezers.
    • Carefully pull out the bundled cable connectors.
结论
另外一个人完成了本指南。
Chris Grabow
于10/08/18注册
285 声望
创作了2篇指南
团队
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 的会员
CPSU-WHITE-F18S17G1
4 名成员
创作了12篇指南
一条评论
Hello, where i can buy the aux cable?
Domenico Rescigno - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 674
