跳转到主内容
加入维修社区 - 创建账户
Dell VRC100-R Touchpad Replacement
你所需要的
    1. Dell VRC100-R Touchpad Replacement, Battery: 步骤 1 中的图像 1,3 Dell VRC100-R Touchpad Replacement, Battery: 步骤 1 中的图像 2,3 Dell VRC100-R Touchpad Replacement, Battery: 步骤 1 中的图像 3,3
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      询问修复机器人
      添加评论
    2. Dell VRC100-R Touchpad Replacement: 步骤 2 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 2 中的图像 2,2
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      询问修复机器人
      添加评论
    1. Dell VRC100-R Touchpad Replacement, Joystick: 步骤 3 中的图像 1,3 Dell VRC100-R Touchpad Replacement, Joystick: 步骤 3 中的图像 2,3 Dell VRC100-R Touchpad Replacement, Joystick: 步骤 3 中的图像 3,3
      • Hold the joystick down with your left thumb to make space for the plastic opening tool.
      • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
      • Slide the plastic opening tool around the perimeter until you can lift the front panel.
      • You may hear a popping noise when you pry off the front panel.
      添加评论
    2. Dell VRC100-R Touchpad Replacement: 步骤 4 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 4 中的图像 2,2
      • Grab the joystick and pull away from the controller to remove it.
      询问修复机器人
      添加评论
    1. Dell VRC100-R Touchpad Replacement, Touchpad: 步骤 5 中的图像 1,2 Dell VRC100-R Touchpad Replacement, Touchpad: 步骤 5 中的图像 2,2
      • Remove one 6mm Phillips #0 screw.
      询问修复机器人
      添加评论
    2. Dell VRC100-R Touchpad Replacement: 步骤 6 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 6 中的图像 2,2
      • Turn your controller over and orient it so that the thin side is on the top.
      • Remove four 4mm Phillips #0 screws.
      询问修复机器人
      添加评论
    3. Dell VRC100-R Touchpad Replacement: 步骤 7 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 7 中的图像 2,2
      • Turn your controller 90 degrees clockwise and insert a plastic opening tool into the crease of the back panel.
      • Push down on the end of the plastic opening tool closest to you to lift the panel up.
      • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
      • You may hear loud popping noises as the back panel separates from the controller.
      询问修复机器人
      添加评论
    4. Dell VRC100-R Touchpad Replacement: 步骤 8 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 8 中的图像 2,2
      询问修复机器人
      添加评论
    5. Dell VRC100-R Touchpad Replacement: 步骤 9 中的图像 1,3 Dell VRC100-R Touchpad Replacement: 步骤 9 中的图像 2,3 Dell VRC100-R Touchpad Replacement: 步骤 9 中的图像 3,3
      • Use the tip of a plastic opening tool or your fingernail to gently flip-up the white locking flap.
      • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
      • Grab the blue cable and pull away from the socket.
      • To reinstall, insert the blue cable into the connector and close the flap on the black line.
      询问修复机器人
      添加评论
    6. Dell VRC100-R Touchpad Replacement: 步骤 10 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 10 中的图像 2,2
      • Place two fingers on the perimeter of the daughterboard and fold it down along the orange cable.
      询问修复机器人
      添加评论
    7. Dell VRC100-R Touchpad Replacement: 步骤 11 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 11 中的图像 2,2
      • Remove two black 6mm Phillips #0 screws.
      询问修复机器人
      添加评论
    8. Dell VRC100-R Touchpad Replacement: 步骤 12 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 12 中的图像 2,2
      • Pinch the black ring on the top of your controller and pull toward yourself to disconnect it.
      询问修复机器人
      添加评论
    9. Dell VRC100-R Touchpad Replacement: 步骤 13 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 13 中的图像 2,2
      • Remove three 3mm Phillips #0 screws.
      询问修复机器人
      添加评论
    10. Dell VRC100-R Touchpad Replacement: 步骤 14 中的图像 1,2 Dell VRC100-R Touchpad Replacement: 步骤 14 中的图像 2,2
      • Insert your finger underneath the black plastic "V" and scoop up to remove it.
      询问修复机器人
      添加评论
    11. Dell VRC100-R Touchpad Replacement: 步骤 15 中的图像 1,3 Dell VRC100-R Touchpad Replacement: 步骤 15 中的图像 2,3 Dell VRC100-R Touchpad Replacement: 步骤 15 中的图像 3,3
      • Place your thumb on the outer edge of the touchpad on the other side of the controller.
      • Push toward the center of the circle to get your fingernail underneath the touchpad then scoop away from yourself.
      • You can see the detachable black flaps underneath the touchpad along the perimeter.
      • Turn your controller over and remove the touchpad.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Steven Pineda
于04/16/18注册
1,049 声望
创作了3篇指南
团队
Cal Poly, Team S18-G3, Livingston Spring 2018 Cal Poly, Team S18-G3, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G3
4 名成员
创作了15篇指南
1指南评论
where to get the replacement for touchpad?
Kenneth Alvarez - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 38
总计 1,529
