简介
If many parts of your controller, like the buttons and touchpad, do not function properly, you have found the correct guide. This guide requires a plastic opening tool, spudger, and Phillips #0 screwdriver head. You will not need any expert knowledge, but you will have to take apart most of your controller.
你所需要的
Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
Slide the cover off and separate it from the controller.
Hold the joystick down with your left thumb to make space for the plastic opening tool.
Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
Slide the plastic opening tool around the perimeter until you can lift the front panel.
Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
Push down on the end of the plastic opening tool closest to you to lift the panel up.
Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
另外一个人完成了本指南。
4条评论
Thanks, using this as a tear down guide.
Hi, do anyone know where this motherboard can be purchased?
where can i buy the motherboard?
