跳转到主内容
Dell VRC100-R Daughterboard Replacement
你所需要的
  1. Dell VRC100-R Daughterboard Replacement, Battery: 步骤 1 中的图像 1,3 Dell VRC100-R Daughterboard Replacement, Battery: 步骤 1 中的图像 2,3 Dell VRC100-R Daughterboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
  2. Dell VRC100-R Daughterboard Replacement: 步骤 2 中的图像 1,2 Dell VRC100-R Daughterboard Replacement: 步骤 2 中的图像 2,2
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
  3. Dell VRC100-R Daughterboard Replacement, Joystick: 步骤 3 中的图像 1,3 Dell VRC100-R Daughterboard Replacement, Joystick: 步骤 3 中的图像 2,3 Dell VRC100-R Daughterboard Replacement, Joystick: 步骤 3 中的图像 3,3
    • Hold the joystick down with your left thumb to make space for the plastic opening tool.
    • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
    • Slide the plastic opening tool around the perimeter until you can lift the front panel.
    • You may hear a popping noise when you pry off the front panel.
  4. Dell VRC100-R Daughterboard Replacement: 步骤 4 中的图像 1,2 Dell VRC100-R Daughterboard Replacement: 步骤 4 中的图像 2,2
    • Grab the joystick and pull away from the controller to remove it.
  5. Dell VRC100-R Daughterboard Replacement, Daughterboard: 步骤 5 中的图像 1,2 Dell VRC100-R Daughterboard Replacement, Daughterboard: 步骤 5 中的图像 2,2
    • Remove one 6mm Phillips #0 screw.
  6. Dell VRC100-R Daughterboard Replacement: 步骤 6 中的图像 1,2 Dell VRC100-R Daughterboard Replacement: 步骤 6 中的图像 2,2
    • Turn your controller over and orient it so that the thin side is on the top.
    • Remove four 4mm Phillips #0 screws.
  7. Dell VRC100-R Daughterboard Replacement: 步骤 7 中的图像 1,2 Dell VRC100-R Daughterboard Replacement: 步骤 7 中的图像 2,2
    • Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
    • Push down on the end of the plastic opening tool closest to you to lift the panel up.
    • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
    • You may hear loud popping noises as the back panel separates from the controller.
  8. Dell VRC100-R Daughterboard Replacement: 步骤 8 中的图像 1,2 Dell VRC100-R Daughterboard Replacement: 步骤 8 中的图像 2,2
  9. Dell VRC100-R Daughterboard Replacement: 步骤 9 中的图像 1,3 Dell VRC100-R Daughterboard Replacement: 步骤 9 中的图像 2,3 Dell VRC100-R Daughterboard Replacement: 步骤 9 中的图像 3,3
    • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the white locking flap.
    • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
    • Grab the blue cable and pull away from the socket.
    • To reinstall, insert the blue cable into the connector and close the flap on the black line.
  10. Dell VRC100-R Daughterboard Replacement: 步骤 10 中的图像 1,3 Dell VRC100-R Daughterboard Replacement: 步骤 10 中的图像 2,3 Dell VRC100-R Daughterboard Replacement: 步骤 10 中的图像 3,3
    • Use the tip of a spudger or your fingernail to gently flip-up the small white flap holding the orange ribbon cable.
    • Grab the orange cable and pull away from the socket.
    • To reinstall, insert the orange cable into the connector and close the flap on the white line.
  11. Dell VRC100-R Daughterboard Replacement: 步骤 11 中的图像 1,2 Dell VRC100-R Daughterboard Replacement: 步骤 11 中的图像 2,2
    • Place two fingers on the perimeter of the daughterboard and lift it away from the controller.
结论
15等其他人完成本指南。
Steven Pineda
于04/16/18注册
881 声望
创作了3篇指南
团队
Cal Poly, Team S18-G3, Livingston Spring 2018 Cal Poly, Team S18-G3, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S18G3
4 名成员
创作了5篇指南
一条评论
Really instructive & easy to follow!
Daisy Chavez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 5,647
