跳转到主内容
Dell Studio 1555 RAM Replacement
你所需要的
  1. Dell Studio 1555 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 RAM Replacement: 步骤 2 中的图像 1,3 Dell Studio 1555 RAM Replacement: 步骤 2 中的图像 2,3 Dell Studio 1555 RAM Replacement: 步骤 2 中的图像 3,3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 RAM Replacement: 步骤 3 中的图像 1,1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 RAM Replacement, Back Panel: 步骤 4 中的图像 1,3 Dell Studio 1555 RAM Replacement, Back Panel: 步骤 4 中的图像 2,3 Dell Studio 1555 RAM Replacement, Back Panel: 步骤 4 中的图像 3,3
    • Loosen the three 5mm screws from the back panel using the # 1 Philips screwdriver.
    • The three 5mm screws will stay in place on the back panel.
  5. Dell Studio 1555 RAM Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the separated back panel.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are unscrewed all the way before attempting again.
  6. Dell Studio 1555 RAM Replacement, RAM: 步骤 6 中的图像 1,3 Dell Studio 1555 RAM Replacement, RAM: 步骤 6 中的图像 2,3 Dell Studio 1555 RAM Replacement, RAM: 步骤 6 中的图像 3,3
    • Press the tabs outwards to release the tabs. The memory stick is spring loaded and will be released at an angle.
  7. Dell Studio 1555 RAM Replacement: 步骤 7 中的图像 1,1
    • Gently remove the memory stick from the slot.
  8. Dell Studio 1555 RAM Replacement: 步骤 8 中的图像 1,2 Dell Studio 1555 RAM Replacement: 步骤 8 中的图像 2,2
    • Once the first memory stick is removed, press the tabs outwards to release the tabs. The memory stick is spring loaded and will be released at an angle.
  9. Dell Studio 1555 RAM Replacement: 步骤 9 中的图像 1,2 Dell Studio 1555 RAM Replacement: 步骤 9 中的图像 2,2
结论
3等其他人完成本指南。
Josh Boone
于10/10/16注册
586 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 1,030
