简介
You may need to replace your keyboard due to failure. You will need a Phillips 1 screwdriver for this guide.
你所需要的
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
即将完成!
结论
2等其他人完成本指南。
