跳转到主内容
加入维修社区 - 创建账户
Dell Studio 1555 Back Panel Removal
你所需要的
  1. Dell Studio 1555 Back Panel Removal, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Back Panel Removal: 步骤 2 中的图像 1,3 Dell Studio 1555 Back Panel Removal: 步骤 2 中的图像 2,3 Dell Studio 1555 Back Panel Removal: 步骤 2 中的图像 3,3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Back Panel Removal: 步骤 3 中的图像 1,1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Back Panel Removal, Back Panel: 步骤 4 中的图像 1,3 Dell Studio 1555 Back Panel Removal, Back Panel: 步骤 4 中的图像 2,3 Dell Studio 1555 Back Panel Removal, Back Panel: 步骤 4 中的图像 3,3
    • Loosen the three 5mm screws from the back panel using the # 1 Philips screwdriver.
    • The three 5mm screws will stay in place on the back panel.
  5. Dell Studio 1555 Back Panel Removal: 步骤 5 中的图像 1,1
    • Carefully remove the separated back panel.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are unscrewed all the way before attempting again.
结论
2等其他人完成本指南。
Josh Boone
于10/10/16注册
586 声望
创作了4篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 799
