跳转到主内容
Dell Streak 10 Pro SD Card Breakout Board Replacement
你所需要的
  1. Dell Streak 10 Pro SD Card Breakout Board Replacement, Battery: 步骤 1 中的图像 1,3 Dell Streak 10 Pro SD Card Breakout Board Replacement, Battery: 步骤 1 中的图像 2,3 Dell Streak 10 Pro SD Card Breakout Board Replacement, Battery: 步骤 1 中的图像 3,3
    • Place the device flat on its screen.
    • Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
    • Take the segment off and place it to the side.
  2. Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 2 中的图像 1,2 Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 2 中的图像 2,2
    • Remove four 4mm Phillips #0 screws.
  3. Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 3 中的图像 1,2 Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, lift off the entire back screen of the tablet.
  4. Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 4 中的图像 1,3 Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 4 中的图像 2,3 Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Disconnect the no-fuss ribbon cable connector.
    • The best way is to safely pull the white connector straight out of the socket. Using the tweezers, pull out the white connector that contains the red, green, blue, and black cords connected to it.
    • Remove the battery by gently lifting it out of the device.
  5. Dell Streak 10 Pro SD Card Breakout Board Replacement, SD Card Breakout Board: 步骤 5 中的图像 1,2 Dell Streak 10 Pro SD Card Breakout Board Replacement, SD Card Breakout Board: 步骤 5 中的图像 2,2
    • Remove three 4mm Phillips #0 screws.
  6. Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 6 中的图像 1,2 Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 6 中的图像 2,2
    • Gently lift up the black covered wire and place it on the side, so that it is not in the way of the procedure.
  7. Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 7 中的图像 1,3 Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 7 中的图像 2,3 Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • When encountering a zero insertion force connector, the best way it to carefully use tweezers to flip up the white locking flap securing the blue-tipped ribbon cable.
    • Then, gently use the tweezers to pull out the blue-tipped ribbon cable from the unlatched connector.
  8. Dell Streak 10 Pro SD Card Breakout Board Replacement: 步骤 8 中的图像 1,1
    • Use two fingers and gently pull the SD card breakout board from its space.
结论
Kayji Arai
于02/05/19注册
211 声望
创作了2篇指南
团队
UC Davis, Team S20-G7, Lore Winter 2019 UC Davis, Team S20-G7, Lore Winter 2019 的会员
UCD-LORE-W19S20G7
2 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 166
