简介
If you need to replace an old or broken SD Card Breakout Board, access the backside of the tablet and release the breakout board from the motherboard. For this guide, you will need a plastic opening tool, a Phillips#0 screwdriver, and tweezers.
你所需要的
Place the device flat on its screen.
Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
Take the segment off and place it to the side.
When encountering a zero insertion force connector, the best way it to carefully use tweezers to flip up the white locking flap securing the blue-tipped ribbon cable.
Then, gently use the tweezers to pull out the blue-tipped ribbon cable from the unlatched connector.
