跳转到主内容
Dell Precision T5600 RAM Replacement
  1. Dell Precision T5600 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Lay the case on its side with the handle side pointing up. Remove the side panel of the computer case by pulling on the handle, as shown in this step.
    • Be sure to use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Dell Precision T5600 RAM Replacement: 步骤 2 中的图像 1,1
    • Unlock the RAM by pressing down on the tabs on each end of the RAM socket.
    • Once both tabs have been pushed down, gently pull out the existing RAM stick from the motherboard.
  3. Dell Precision T5600 RAM Replacement: 步骤 3 中的图像 1,2 Dell Precision T5600 RAM Replacement: 步骤 3 中的图像 2,2
    • Line up the RAM with the groove on the connector line.
    • Do not touch the gold connectors.
  4. Dell Precision T5600 RAM Replacement: 步骤 4 中的图像 1,2 Dell Precision T5600 RAM Replacement: 步骤 4 中的图像 2,2
    • Gently insert the RAM into the socket until you feel the tabs from Step 3 click into place.
    • Ensure that both ends of the RAM are secured by their tabs.
  5. Dell Precision T5600 RAM Replacement: 步骤 5 中的图像 1,1
    • Reattach the side panel from Step 2. Plug your computer back up to the power supply and power on your computer.
    • Once powered on, to verify the installation:
    • Right-click on 'This PC'
    • Left-click on 'Properties'
结论
Fahad Khan
于07/05/21注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 916
