跳转到主内容
Dell Precision M6800 Keyboard Replacement
你所需要的
  1. Dell Precision M6800 Keyboard Replacement, Dell Precision M6800: 步骤 1 中的图像 1,1
    • Replacing Dell Precision M6800's keyboard
  2. Dell Precision M6800 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Precision M6800 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Before any repair, you should remove battery
  3. Dell Precision M6800 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Pry and remove the frame around keyboard (it's a bit lighter than rest of casing).
  4. Dell Precision M6800 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Unscrew 4 fastening screws which are at bottom of keyboard
  5. Dell Precision M6800 Keyboard Replacement: 步骤 5 中的图像 1,2 Dell Precision M6800 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Pry out four hooks which are on the sides of keyboard (two per one site)
    • Be carefull to not break of hooks - use constant force and do it slowly
  6. Dell Precision M6800 Keyboard Replacement: 步骤 6 中的图像 1,2 Dell Precision M6800 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Pick up a little keyboard and eject it. Than pick up harder but DO NOT take it out
    • DO NOT take keyboard out, it is connect to the motherboard and you must unhook it in next step
  7. Dell Precision M6800 Keyboard Replacement: 步骤 7 中的图像 1,2 Dell Precision M6800 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Pry up the white part of connector (constant for both sides) and eject connecting flex
结论
4等其他人完成本指南。
2条评论
Great job, thank you
kali1902 - 回复
Broke off the stupid white clip holding the connector in place go to h ell
Stan B - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 9
过去 30 天: 33
总计 1,258
