跳转到主内容
Dell Precision M6700 Hard Drive Replacement
你所需要的
  1. Dell Precision M6700 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Precision M6700 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M6700 Hard Drive Replacement, Base Cover: 步骤 2 中的图像 1,2 Dell Precision M6700 Hard Drive Replacement, Base Cover: 步骤 2 中的图像 2,2
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer
  3. Dell Precision M6700 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Remove the screws that secure the primary hard drive to the computer. Slide the primary hard -drive latch to the unlock position and pull out the hard drive from the computer.
  4. Dell Precision M6700 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
    • NOTE: A rubber filler is installed to the hard-drive bracket for 7 mm hard drives. It is designed to prevent vibrations and for correct installation of the 7 mm hard drives. 9 mm hard drives do not require the filler when installed into the hard-drive bracket.
  5. Dell Precision M6700 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the screw that secure that secondary hard drive in place.
    • Pull the tab upward and remove the secondary hard drive from the computer.
  6. Dell Precision M6700 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the screw that secure secondary hard drive to the bracket.
    • Remove the secondary hard drive from the bracket.
结论
4等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
44,820 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 37
总计 4,770
