跳转到主内容
Dell Precision M6600 Hard Drive Replacement
你所需要的
  1. Dell Precision M6600 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: 步骤 2 中的图像 1,2 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: 步骤 2 中的图像 2,2
    • Using Phillips screwdriver, remove 2 screws holding case.
    • Slide case towards back of laptop then lift off to remove.
  3. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: 步骤 3 中的图像 1,2 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: 步骤 3 中的图像 2,2
    • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
    • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
  4. Dell Precision M6600 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
结论
4等其他人完成本指南。
Kaley lindsay
于03/23/18注册
582 声望
创作了4篇指南
团队
一条评论
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 38
总计 3,588
