跳转到主内容
Dell Precision M6400 Memory Module Replacement
你所需要的
  1. Dell Precision M6400 Memory Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 Memory Module Replacement, Base Cover: 步骤 2 中的图像 1,1
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 Memory Module Replacement, LED Cover: 步骤 3 中的图像 1,1
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
  4. Dell Precision M6400 Memory Module Replacement, KeyBoard: 步骤 4 中的图像 1,1
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
  5. Dell Precision M6400 Memory Module Replacement, Memory Module: 步骤 5 中的图像 1,1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
结论
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
45,540 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,993篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,463
