跳转到主内容
Dell Precision M4700 Optical Drive Replacement
你所需要的
  1. Dell Precision M4700  Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M4700  Optical Drive Replacement: 步骤 2 中的图像 1,2 Dell Precision M4700  Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the two 3mm screws that secure the base cover to the computer with a Phillips #00 screwdriver.
    • Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Dell Precision M4700  Optical Drive Replacement: 步骤 3 中的图像 1,2 Dell Precision M4700  Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Remove the 3mm screw that secures the optical drive to the computer with a Phillips #00 screwdriver.
    • Slide the optical drive out.
结论
另外一个人完成了本指南。
Dylan
于10/30/19注册
361 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 19
总计 453
