跳转到主内容
加入维修社区 - 创建账户
Dell Precision M4600 Memory Module Replacement
你所需要的
  1. Dell Precision M4600 Memory Module Replacement, Battery: 步骤 1 中的图像 1,2 Dell Precision M4600 Memory Module Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the battery release latch into the unlock position.
    • Remove the battery from the system.
    询问修复机器人
    添加评论
  2. Dell Precision M4600 Memory Module Replacement, Base Cover: 步骤 2 中的图像 1,3 Dell Precision M4600 Memory Module Replacement, Base Cover: 步骤 2 中的图像 2,3 Dell Precision M4600 Memory Module Replacement, Base Cover: 步骤 2 中的图像 3,3
    • Remove the screws that secure the base cover to the computer.
    • Press the rubber feet towards the rear of the system to disengage the bottom door.
    • Remove the base cover from the computer.
    询问修复机器人
    添加评论
  3. Dell Precision M4600 Memory Module Replacement, Keyboard Trim: 步骤 3 中的图像 1,3 Dell Precision M4600 Memory Module Replacement, Keyboard Trim: 步骤 3 中的图像 2,3 Dell Precision M4600 Memory Module Replacement, Keyboard Trim: 步骤 3 中的图像 3,3
    • Using a plastic scribe, pry under the keyboard trim to release it from the computer.
    • Work your way around the sides and bottom edge of the keyboard trim.
    • Lift up to remove the keyboard trim from the unit.
    询问修复机器人
    添加评论
  4. Dell Precision M4600 Memory Module Replacement, KeyBoard: 步骤 4 中的图像 1,3 Dell Precision M4600 Memory Module Replacement, KeyBoard: 步骤 4 中的图像 2,3 Dell Precision M4600 Memory Module Replacement, KeyBoard: 步骤 4 中的图像 3,3
    • Remove the screws securing the keyboard in place.
    • Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
    • Disconnect the keyboard data cable from the system board.
    询问修复机器人
    添加评论
  5. Dell Precision M4600 Memory Module Replacement: 步骤 5 中的图像 1,3 Dell Precision M4600 Memory Module Replacement: 步骤 5 中的图像 2,3 Dell Precision M4600 Memory Module Replacement: 步骤 5 中的图像 3,3
    • Remove the keyboard.
    • Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
    • Disconnect the keyboard data cable from the back of the keyboard.
    询问修复机器人
    添加评论
  6. Dell Precision M4600 Memory Module Replacement: 步骤 6 中的图像 1,1
    • Peel the keyboard data cable away from the keyboard and remove.
    询问修复机器人
    添加评论
  7. Dell Precision M4600 Memory Module Replacement, Memory Module: 步骤 7 中的图像 1,2 Dell Precision M4600 Memory Module Replacement, Memory Module: 步骤 7 中的图像 2,2
    • Flip the the Bottom
    • Gently pry the retention clips away from the memory modules.
    • Remove the memory modules from the computer.
    询问修复机器人
    添加评论
  8. Dell Precision M4600 Memory Module Replacement: 步骤 8 中的图像 1,2 Dell Precision M4600 Memory Module Replacement: 步骤 8 中的图像 2,2
    • Flip to the Top.
    • Gently pry the retention clips away from the memory module.
    • Remove the memory module from the computer.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Johnathan Hammond
于02/28/18注册
46,149 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
45 名成员
创作了2,002篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 35
总计 1,643
