跳转到主内容
Dell Precision M4400 Hard Drive Replacement
你所需要的
  1. Dell Precision M4400 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery release latches to the open position. (The latches lock into place).
    • Grip the battery and slide it out of the battery bay.
  2. Dell Precision M4400 Hard Drive Replacement, Base Cover: 步骤 2 中的图像 1,1
    • Loosen the M2.5 x 5-mm captive screw.
    • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
  3. Dell Precision M4400 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Dell Precision M4400 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • NOTICE: When the hard drive is not in the computer, store it in protective anti-static packaging.
    • Remove the four M3 x 3-mm screws securing the hard drive. These screws are on the bottom of the base cover.
    • NOTE: If the bottom of the base cover is detached from the laptop, the four screws securing the hard drive are marked with an "H".
    • Slide the hard drive out of the computer.
    • Remove the face plate screw and then the face plate from the hard drive.
结论
Johnathan Hammond
于02/28/18注册
44,980 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 1,148
