跳转到主内容
Dell Precision M3800 Touch Pad Replacement
你所需要的
  1. Dell Precision M3800 Touch Pad Replacement, Back Cover: 步骤 1 中的图像 1,2 Dell Precision M3800 Touch Pad Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Touch Pad Replacement: 步骤 2 中的图像 1,1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Touch Pad Replacement, Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Touch Pad Replacement, Touch Pad: 步骤 4 中的图像 1,3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: 步骤 4 中的图像 2,3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: 步骤 4 中的图像 3,3
    • Remove the wire that connects the touch pad with the motherboard with a hooked pry tool (Spudger 3) and by pulling the pull tab to safely remove the wire.
  5. Dell Precision M3800 Touch Pad Replacement: 步骤 5 中的图像 1,2 Dell Precision M3800 Touch Pad Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the two 2mm silver screws.
  6. Dell Precision M3800 Touch Pad Replacement: 步骤 6 中的图像 1,1
    • Remove the touch pad from the laptop. If needed, use a prying tool to remove the touch pad.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 987
